Latest post 03-01-2009 5:01 AM by The_Beonic_Man. 4 replies.
Page 1 of 1 (5 items)
  • 03-01-2009 2:23 AM
    • mhh
    • Not Ranked
    • Joined on 11-05-2007
    • Adelaide
    • Posts 6
    Beosound 3 died
    I've had my Beosound 3 on charge for weeks but haven't used it.  Now it won't turn on.  Is there a way to re-boot it without opening it or sending to B&O for repairs?
  • 03-01-2009 2:51 AM In reply to
    Re: Beosound 3 died
    Dependent on how old it is, the silver foil membrane under the keypad on early models required replacement, often leading people to believe their Beosound 3 had died.  3 weeks charge is a bit excessive but should be ok.
  • 03-01-2009 4:03 AM In reply to
    • mhh
    • Not Ranked
    • Adelaide
    • Posts 6
    Re: Beosound 3 died
    Thanks.
    Is there a problem leaving it on mains power?  I always have it plugged in to keep it charged up....
  • 03-01-2009 4:11 AM In reply to
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Re: Beosound 3 died
    Heya you can keep it plugged. Nothing bad about it.
  • 03-01-2009 5:01 AM In reply to
    Re: Beosound 3 died
    I had the same problem with mine and got it repaired under warranty. As the previous poster mentioned there is a known fault with the ealrier models. I also find at times that I get electric shocks when unplugging it from charging. It is currently with the dealer again to check over the PSU. Has anyone else encountered this?
    Simon.
