Latest post 03-02-2009 8:12 AM by Gerd. 7 replies.
Page 1 of 1 (8 items)
  • 02-28-2009 7:51 AM
    BeoCenter 6 - 23 Autoformat
    Hello all,
    I have connected a DVB-T box to a BeoCenter 6 - 23 type 9212 with a scartcable.
    The problem is that when i shift to the DVB-T box output(VMEM) the tv cannot sense the format change. Meaning: the tv starts in format 1(which is the wrong format, because im missing top and bottom of the picture). The correct format is format 3 which i have to change to manually. I have tried changing the settings in the service menu (WSS). And this doesnt help.
    Anybody has an idea to a solution to my problem.
    Best regards
    BMGHB
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
    Filed under:
  • 02-28-2009 1:32 PM In reply to
    Re: BeoCenter 6 - 23 Autoformat
    Ensure the DVB-T box has output set to 16:9?
  • 02-28-2009 8:19 PM In reply to
    KingOfSnake:
    Hello King,
    I have. The ouput is 16:9.
  • 03-01-2009 7:28 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    - in service menu set "Auto-Format" to ON and "WSS Status" to DETECT ON
    - ensure you have a fully wired scart cable (check pin 8: 4,5–8 V = 16:9 / 9–12 V = 4:3)
    - try the other scart connector
    - try another receiver
  • 03-01-2009 7:52 AM In reply to
    Hello Gerd,
    I have been in the service menu and tried the changes you refer to.
    I have a fully wired scart cable.
    I will try another scartconnector and another receiver.
    Thanks for the good advice.
    BMGHB
  • 03-01-2009 8:05 AM In reply to
    • Gerd
    • Germany
    • Posts 523
    If you have a meter check the voltage at pin 8 in order to see if the receiver
    output is correct. You can also try to connect a DVD Player or anything else
    with 16:9 output instead.
  • 03-02-2009 7:27 AM In reply to
    Hello Gerd,
    I have just been informed by Bang & Olufsen that BC6-23 doesnt have "black bar detection".
    It means that it cant measure the proper picture to show unless the connected hardware sends a format video signal.
    Pin 8 works fine, because i am controlling the DVBT box with my beo4 remote via pin 8.
    I guess i am at the end of the line here. But thanks gor you good ideas and input.
    BMGHB
  • 03-02-2009 8:12 AM In reply to
    • Gerd
    • Germany
    • Posts 523
    That's correct, it should however be able to detect the voltage at pin 8 (if the
    box gives out the correct voltage)!
    What do you mean by "controlling the DVBT box with beo4 remote via pin 8"?
    Do you mean that the box switches on/off when the TV goes on/off?
