Latest post 02-28-2009 10:46 PM by Weebyx. 3 replies.
Page 1 of 1 (4 items)
  • 02-27-2009 3:35 PM
    • Rob
    • Not Ranked
    • Joined on 04-16-2008
    • Windsor
    • Posts 5
    • Silver Member
    Programming the Beo5 for Windows Media Centre
    Hi All,
    I'm having another go at trying to re-program the Beo5 to work Windows Media Centre. But I'm not getting very far.
    Does anyone know how to do this?
    R
  • 02-28-2009 1:37 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Re: Programming the Beo5 for Windows Media Centre
    What is your setup, do you have a B&O tv or do you plan to control it directly ?
    I have written a small how-to here
    http://www.rungwald.dk/Beo4-5_MCE_Control/
    I myself control MCE via the MCE original IR reciver and the STB-Controller of my Beosystem 3, and have just add'ed pages and buttons to the Beo5 that sends the codes i have mapped.
    That is, i am using this http://www.rungwald.dk/Beo4-5_MCE_Control/stb.html
    Please tell me more about your setup before i can guide you in what you should do.
    /Weebyx
  • 02-28-2009 5:24 AM In reply to
    • Rob
    • Not Ranked
    • Windsor
    • Posts 5
    • Silver Member
    I have the BeoSystem3 so I guess I should control it using this.
    But I don't have the HomeChoice PVR which you have mentioned.
    I guess in order to use this, I'd have to obtain an update? Is there anyway of finding out the level of s/ware the BS3 has?
    Thanks for your help
  • 02-28-2009 10:46 PM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    Rob:
    Just ask your dealer to add the Homechoice PVR to your STB  list, or you could run all your STB's against the HIP program, to see if any off yor STB's will be recognised by HIP. If so you dont need your dealer, i just uséd the homechoice because it was in my tv and it worked
    /weebyx
