I suspect the OP finds the time delay between the digital signal as heard in the main room and the analogue signal in the link room to be objectionable. This effect can be minimized by changing the Sound Delay setting under Monitor/Sound Adjustments in the hidden Service Menu from the default number (I forget what it is) to 0 (zero). Unfortunately, this does not eliminate the problem completely, but it does make it more or less bearable.
