Latest post 03-01-2009 1:35 PM by Tim. 4 replies.
Page 1 of 1 (5 items)
  • 02-27-2009 1:34 AM
    Internet Radio via FrontRow - Solution!
    I hope this is not redundant information for you folks here:
    You can also listen to internet radio using FrontRow: Just create a new playlist in iTunes and drag&drop any desired radio station into that playlist. You can then access the playlist entries in FrontRow as well. Works like a champ!
    Cheers, Knubbi -- Beovision 7-40 MK3, 2x Beolab 5, 2x Beolab 8000
  • 02-28-2009 2:38 PM In reply to
    Re: Internet Radio via FrontRow - Solution!
    fantastic tip thanks......
    Shame you can no longer stream to airtunes unless you reinstall the original frontrow!!!
  • 03-01-2009 5:01 AM In reply to
    • Tim
    • Top 500 Contributor
    • Joined on 05-19-2008
    • Munich
    • Posts 121
    gk31ax:
    Have you tried airfoil already? This is the too of my choice Wink
  • 03-01-2009 6:11 AM In reply to
    are you telling me I can stream from frontrow using airfoil??
  • 03-01-2009 1:35 PM In reply to
    • Tim
    • Munich
    • Posts 121
    airfoil is a tool that can stream all audio from the mac to the Airport Express.
    Just try the demo from the site Big Smile
