Latest post 02-26-2009 11:33 AM by Daniel. 8 replies.
Page 1 of 1 (9 items)
  • 02-25-2009 3:32 PM
    BeoLab 2000 Connection
    Hello!
    My current system is configured this way but I would like to hook up a BeoLab 2000 I have from a different room.
    BeoSystem 1 to BV4-42 through VGA; BC2 to BS1 through Masterlink
    Fronts- BL8000; Rears- BL6000; Center- BL4000; Sub- BL2
    How can I hook up this BL2000 (from another room) to my system so I can control with a Beo4? (please note I only have one masterlink coming out of the BS1 and it is being used by the BC2)
    Thanks,
    Diggs
  • 02-25-2009 3:41 PM In reply to
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Re: BeoLab 2000 Connection
    The easiest way:
  • 02-25-2009 3:44 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Hi Diggs
    In simple terms, you buy another Masterlink cable of whatever length you need to get from the BeoLab2000 to somewhere covenient to connect into your existing Master link cable.
     Chop the plug off one end of the cable. The "jointing" of the two cables can either be done with a Bang & Olufsen ML junction box, or simply using a terminal strip to re-connect the coloured strands in the cable.  If you go for the second option, you need to remeber to short the pink and blue stripped cables together.  This happens automatically if you use thte proper junction box.
    It is important to power off you system BEFORE cutting into the ML cable.  Connect everything up then switch the mains back on.
    Opman
  • 02-25-2009 3:46 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    The ML splitter box is certainly the easiest way and requires no re-connecting of cables but if you have to run your cable through a wall it will require a big hole to get the ML plug through it.
    Opman
  • 02-25-2009 4:16 PM In reply to
    How much does the masterlink splitter box run? Will it still recognize the difference between the BC2 and BL2000?
  • 02-25-2009 5:02 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    The ML system enables audiomaster (BC2) and videomaster (BV4) to communicate and sending sound both ways. It also allow link speakers (BL 2000) and slaves (a stereo in link mode) to receive sound from the master and also controlling the masters.
    So, no problem. The ML system is just a connection between your products. And they will know how to talk to each others.
  • 02-25-2009 5:13 PM In reply to
    • KibitoCH
    • Switzerland
    • Posts 82
    Splitter Box big:
    And small:
  • 02-25-2009 5:14 PM In reply to
    • KibitoCH
    • Switzerland
    • Posts 82
    Splitter Box small:
    And the big one:
  • 02-26-2009 11:33 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Never seen the big one before. Connecting four cables in the small one wasn´t easy. Looks easier with the big one.
