Peter and Graham are correct (as always!)
however, there is one important point to remember....
Beogram turntables without built-in pre-amps use pin 7 for Datalink and pin 6 for Data Ground, whereas BeoSystem 2300 will be designed to work with the later (pre-amplified) Beograms which use pin 6 for Datalink and pin 7 for Data Ground. Trust B&O to confuse things! ![Hmm](http://forum.beoworld.org/emoticons/35.gif)
Hence, if you add an external pre-amp, you will need to swap these two pins over when connecting the Datalink wires. Most "off-the-shelf" pre-amp kits do not include Datalink wires, but any competent cable supplier should be able to add these for you if required.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
