Hello,
I am having issues with Beo4 working with the BS3200. The old setup had the BS3200 connected to a BeoSystem 1 through masterlink and setup as a video option (1 or 2). The beo4 worked perfectly with the BS3200 this way.
Just recently I replaced the BS3200 with a beocenter 2. So now the BS3200 will have speakers hooked up directly (another room) but the beo4 is not working correctly with it (does not switch from CD to Radio or have any response). Any Ideas? Do I need to switch the option on the BS3200 to (0)?
Thanks!
Diggs
No, not option 0.That will make it receive no IR signal at all.If the 3200 is now stand alone, and not connected to the rest of the system, it needs to be in Audio Option 1. (or 2)
Poor me, never win owt!
Can I change it right on the BS3200 to Option 1 or do I have to do it through the beo4? If so, how?
Press Standby and List at the same time on the Beo4, cycle through to OPTION? on the display, press the Go button, cycle through to A.OPT? on the display and press 1.
The light on the BeoSound 3200 should flash to acknowledge it's new option mode.
Weekly top artists:
Worked like a charm!!
