1st March February 2012
Latest post 03-10-2009 6:01 PM by beolife. 22 replies.
02-24-2009 5:15 AM
Noelke
- Joined on 10-07-2008
- Posts 26
IC chip STB-C version 4.06
Does anyone know which Set-Top-Box devices are supported by the IC chip version 4.06 STB-C?
It is not installed so I can not check it via the TV-menu.
KibitoCH
- Joined on 02-19-2009
- Switzerland
- Posts 82
Re: IC chip STB-C version 4.06
Sorry, had to delete. They brought out a new Version wich totaly replaced 4.06.
New Version is 4.12. I will add the info soon.
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Do you have the lists for the other regions as well ?
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
I would also be interested in knowing if the list of supported devices for other European regions (specifically UK)
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
Ignace
- Moderator - NL
- Posts 2,749
Many thanks for sharing the file !
Noelke
- Posts 26
But I still would like to know the complete list of version 4.06
So if someone can help me with this ?!
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
I think the following list is what you may be looking for:-
Many members in the UK will be particularly interested in the fact that the Virgin V+ is included in the list which was a pleasant surprise.
West Europe 4.11
1. HUMAX Cl-51 OOC 2. Humax IRHD-5000C 3. Humax IR-FOX C 4. Humax IPVR 9200C 5. HUMAX PVR 9200T 6. HUMAX HDCI-2000 7. Philips DCR 1211/18 8. Philips DSR7005 9. Philips DCR 7101/03 10. Philips DSR7121/22 11. TF4000PVR 12. T.FIELD 771 OHDPVR 13. TF5800PVR 14. TF581 OPVRt 15. TF5000PVR 16. MOTORO. DVi5000 17. DREAMBOX DM7000 18. SA Exp 8455DVB 19. Virgin V+ 20. BT Vision 21. HUMAX FOX SAT HDR 22. Technomate TM5000 23. PACE SKY+ 24. SKY DIGITAL 25. Apple Remote 26. ASTON XENA 1600 27. KreatelIP-STB 1760 28. SAMSUNG DCB9401 29. SAMS. DCB-H360R 30. Samsung DCB-B270R 31. Samsung DCB-P850RS 32. SAMSUNG SMT1xOO 33. Sony Playstation 3 34. CANALdigital B+ 35. CANALdigital NL 36. indi 5800C RAW 37. STARHUB 38. TELENET DBAD101 39. Belgacom TV 40. TViX M6500A HD 41. Thomson DCI52NUM 42. Thomson DCI62UPC 43. Thomson SkyHD 44. REBOX RE-1150CO 45. REBOX RE-1250CO
KibitoCH
- Switzerland
- Posts 82
Noelke:
I'm afraid the Ordering number for the new Chip is the same as the old one. So i belive you can't order it anymore (shrug maybe im wrong and you somehow still can manage to get one). I got the list on my laptop, can check tomorrow if you still need it by then.
Noelke
- Posts 26
Yes please, that would help me. I do have the IC chip 4.06 but not yet build in my B&O TV.
Before doing so and dismanteling the rear cover etc. of my TV, I would like to know which devices it supports to prevent that all the work is done with no results at the end .
Many thanks!
k984942
- London, UK
- Posts 194
Hi Keith,
Could you confirm that the latest STB-C IC for the UK is 4.11?
I have written to B&O and they claim its 4.10
Keith Saunders
- Posts 3,810
Version 4.11 is the latest available.
You can review the complete list HERE
k984942
- London, UK
- Posts 194
Thanks Keith...I knew you'd be right!
ouverture
- Joined on 04-20-2007
- London
- Posts 282
Re: IC chip STB-C CENTRAL EUROPE any version
if anyone has for sale a Central Europe IC Chip ( any version 4.02, 4.06 or 4.12), I would really be grateful if they could get in touch, thanks.
ouverture
- London
- Posts 282
if one has an old STB-C with IC Chip ver 3.6, can you simply change like for like a newer ver 4.06 or later chip ??
thanks
Peter
Keith Saunders
- Posts 3,810
Peter,
The simple answer is "Yes you can"
ouverture
- London
- Posts 282
that's good to know, will contact my dealer on Monday, many thanks
beolife
- Joined on 04-19-2007
- Posts 163
I have a Philips DTR220/05 freeview box , does anyone know if this is supported as I can not see it in the latest list posted.
Will one of the other Philips models be similar?
Keith Saunders
- Posts 3,810
beolife:
Simon,
Most Philips STB's use remotes which conform to protocol RC5 or RC6 which were originally developed by Philips.
Have a look on the back of the DTR220/05 remote for its number which will normally start "RC???" and then from this I can answer your question.
beolife
- Posts 163
Hi Keith,
The remote does not have any codes on it, do you think that the model no of the box ends in 05 is the rc code.
Page 1 of 1 (23 items)
