Latest post 02-26-2009 12:14 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 02-23-2009 4:25 PM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    Avant - Sky - BS7000 -V8000
    Hi.
    I have my avant RF32" DVD linked to a standard sky box and a V8000 and a BS7000.
    I recently disconnected the tape deck to have work done on it (it is now reconnected)
    Ever since disconnecting it when i press DTV on my Beo 4 the main screen turns on and remains blank whereas it used to come on to whatever channel i was watching before.
    Now i have to go into the STB menu (menu >1) to select TV guide on the sky main menu.
    Has anyone got any ideas how to remedy this?
    Thanks in anticipation to any help you may have
    Fil
  • 02-23-2009 5:11 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Avant - Sky - BS7000 -V8000
    Fil, have you tried unplugging everything, waiting 10 mins or so. Then plugging it all back in again. This seems to cure a wide range of problems.LaughingLaughing
    CraigSmile
  • 02-26-2009 3:24 AM In reply to
    • Fil
    • Posts 90
    Yep tried that....still no luck.
    It seems like it's only doing it after being turned off for a longer period ie over night.
    After Just a couple of hours the it all turns on just like it should.
    Anyone else any suggestions please
    Fil
  • 02-26-2009 12:14 PM In reply to
    Has the set up of the Avant changed? Check that the sockets are assigned correctly. Sometimes removing something can upset things!
