Done. C10 / 1uF from the +5V power supply (similar axial ROE...) was dead as well, replaced by a Wima MKS. C8 (+34V) replaced.
C68, C65 and C59 from the CPU board replaced. All voltages that should be there on standby seem present, still no life at all. Argh.
Edit: one more thing: TR6 (BD138) on the CPU board - the IR transmitter power stage - gets really hot if P22 is connected No change in function otherwise, as far as I understand disconnecting P22 only disables the IR tx & rx...
