Latest post 02-24-2009 12:27 AM by mjmedlo. 2 replies.
Page 1 of 1 (3 items)
  • 02-23-2009 1:49 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    cinema button controls
    what does the cinema button do exactly>
    I've got the configurator and can pull up the cinema button, but how
    do you then add a macro to the "cinema"?
    i want to tell the lights to go down, etc. when i press the button. .
    MJM
    I'm ready for something new that I actually want to buy!
  • 02-23-2009 2:34 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: cinema button controls
    The Cinema button sends this command: 0:000:TV:PICTURE_FORMAT+0:000:TV:CIFFER_0+0:000:TV:PANEL_OFF.
    You can create your own Cinema button and add the macros you want to this new button.
    Quim
  • 02-24-2009 12:27 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    so i can do that with the DVD button as well i presume?
    All i want to do is make the lights go to "red" when i turn on DVD
    thanks for the help
    MJM
