Latest post 02-24-2009 2:37 AM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 02-23-2009 10:26 AM
    How to remove platter on 1800?
    I have a Beogram 1800. I know there are shipping locks located under the platter. How do I lift the platter to access the locks?
  • 02-23-2009 11:34 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: How to remove platter on 1800?
    If it is the BG1800 from the 1980's it will simply lift off.
    They can become a little stuck so you may need to "rock" it by lifting opposite edges alternately whilst using slight pressure in the centre. Welcome to BeoworldSmile
    Chris.
  • 02-23-2009 5:17 PM In reply to
    Yes, that's the one. Thanks for the tip. I'll give it a try.
    Does anyone have any ideas why the motor makes a ticking noise? Maybe there's a bump on the belt or something?
  • 02-24-2009 2:37 AM In reply to
    • Medogsfat
    • Posts 4,045
    Not uncommon with these, it is old and needs replacing ideally. I think member Craig managed to prolong the life of one of these motors (on a Beocenter 2200) by spraying it with WD40 or similar.
    No one makes a replacement motor that I'm aware of but there are lots of Beograms which use the same one if you can find a broken one with a good motor.
    Chris.
    EDIT :-
    As we speak THIS thread has been posted - the motors mentioned are identical to the one your Bg1800Smile
