Hi!
My girlfriend just "inherited" a beocenter 2500 system from her Father.
In addition to radio and CD we want to connect her computer to the beocenter.
I soldered an aux in cable, using wiring information from this site, but no sound can be heard when switched to aux.
Can it be that a voltage must be present on pin 6 of the aux connection? If yes, does any voltage above 3.5 V suffice? So, could i use a small power adaptor with say 5 V connected to pin 6 and the aux in would work?
Or do I have to purchase a (surely not very cheap :-( ) adapter from BO?
Thanks in advance for any information you could give me,
Arndt
Dortmund
Germany
