Latest post 02-22-2009 12:56 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 02-22-2009 8:30 AM
    MX7000 on a LX5500 stand??
    Anyone know if its possible to put an MX7000 on a LX5500 non motorised stand??
    Either as is, or by changing the base plate??
    Gary
  • 02-22-2009 9:56 AM In reply to
    Re: MX7000 on a LX5500 stand??
    The MX7000 should fit on as is. There are only two base plates for 28 inch TV's. One for MX series and one for LX series.
    Regards Graham
  • 02-22-2009 11:06 AM In reply to
    Thanks Graham
    That gives me enough confidence to give it a go!!
    Cheers
    Gary
  • 02-22-2009 12:42 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    I am not convinced!  You asked about an MX on an LX stand - not an MX5500 stand.  The LX stand will be wider to accommodate the different chassis with the speakers to the side rather than below.
    Brian.
  • 02-22-2009 12:56 PM In reply to
    Xseries:
    Brian.
    Correct Brian, I misread the OP. It won't fit unless you change the base plate and I have seen some that were welded on rather than bolted.
    I'll send the OP a PM!
    Regards Graham
