Latest post 02-28-2009 6:44 PM by The_Beonic_Man. 10 replies.
Page 1 of 1 (11 items)
  • 02-21-2009 8:36 AM
    Beocom 6000 -red light flashing on handset
    Hi I am new to the site and wondered if anyone could help me please. I have a Beocom 6000 handset the triangular base unit shows a green light but the handset is continually flashing red. I have misplaced my user manual and it is driving me bonkers trying to fix it. I thought maybe it is the battery that may need replacing but how would the red light flash if the battery is dead? I think mine may be a
    Mark 1 model. Any ideas or tips on how i might fix this please would be very much appreciated. There are some numbers on the base station if it may help they are serial number 106144888225379 the other says park:36-000331417637
  • 02-21-2009 8:56 AM In reply to
    Re: Beocom 6000 -red light flashing on handset
    I have Beocom 2500.
    And if you have some unanswered call it's flashing red until you check all your previous call's.
    Also when you have more than one phone connected in your house it's flassing red when somebody talk on other phone.
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 02-21-2009 12:39 PM In reply to
    • bumble
    • Not Ranked
    • Joined on 05-21-2008
    • USA
    • Posts 21
    Hello -
    First, the light is supposed to flash if:
    -the phone line is in use
    -you've missed a phone call
    -the battery is low
    But you can turn it off:
    To turn off the light -
    Press DOT-7 for the menu -
    Go into settings -
    Select "news indicator"
    Toggle it off
    Have fun!
    Bumble
  • 02-21-2009 7:04 PM In reply to
    Worth checking to see if the charger is actually plugged in and switched on. If the phone is sitting in the charger with the red light flashing this could be the problem, otherwise likely to be a missed call in which case you pick up the handset and press the middle button to view the missed call.
    Simon.
  • 02-22-2009 4:12 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    His base is showing a green light Simon, so it is more likely a missed call.
    Don't forget to scroll through the last 24 caller IDs, in case the missed call was number 23!!
    PS, when the battery is nearly flat, it gives audible bleeps.
    Andy T.
    Poor me, never win owt!
  • 02-22-2009 6:01 PM In reply to
    Jandyt:
    Andy T.
    Will you be upgrading to the new phones when they come out later this year Andy? They have hands free which is a welcome albeit quite late edition! I haven't even seen them but I know I will get them as B&O have never made a bad landline phone in my opinion. My dealer has seen them and played with them at the last dealer conference and said they are awesome both in design and functionality.
    Simon.
  • 02-22-2009 7:30 PM In reply to
    • Jandyt
    • Posts 13,004
    I expect I will get one handset and whatever it comes on. I love the 6000s and have them all over the house but can't understand why they didn't have speaker-phone years ago!
    Beocom 5 (or whatever it's called) is to have speaker-phone and be compatible with the 6000 (alledgedly) so I'm really looking forward to it's release. Hope it's sensibly priced.
  • 02-24-2009 1:19 PM In reply to
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    Pdf version of the manual is available from B&O site here.
  • 02-28-2009 6:13 PM In reply to
    When ive checked it comes up line busy but noone using the phone  and it is the only one i had plugged in. Have tried another phone in the same socket and it works fine. Think im goin to try and replace the battery. How do i replace the battery in the Beocom 6000 ?
  • 02-28-2009 6:34 PM In reply to
    you can get spare Sanyo batteries on ebay, to open up the compartment on the back of the phone, just simply push down the bottom half and it simply comes away to reveal the battery, you can do it with just a bit of thumb pressure.
  • 02-28-2009 6:44 PM In reply to
    Jandyt:
    Same here. I will probably only be in the market for 1 phone because I already bought the 6000s as you did for the rest of the home. No point buying something I don't need. Thinking about it, I only really need 1 hands free one anyway, I'll just put it in the lounge and make sure that's the one I use more than the others when making calls that I know I'll need hands free for, which is pretty much when phoning any UK company customer services these days ... including B&O!
    Simon.
