Well, the saga continues...
The headphone jack it on one side so asthetically it's not too bad.
The set up today is such - the speakers connect to an output on an audio selector with the TV & an iPod set up as inputs. All three connections use RCA cables. But there's another issue that's been bothering me and B&O sales folks have no real answer to this problem - every time I turn the TV or the ipod on or off there's a 'boom' sound from the speakers. Same 'boom' sound if I switch between the inputs via the audio selector.
The BO salesperson today confirmed that this is not good, he also mentioned about the sound coming out of the headphone being pre-amplified and the amplifier built into the speakers not being fully utilized.
My hypothesis is that if I turn the device (TV or iPod) first and then power on the speakers (a couple seconds later) this does not happen. Similarly the opposite sequence before turning the device off. I have manually tried this and it seems to fix the problem.
So the only (not too straightforward) option is to somehow integrate this programmatically using my IR/RF capable Logitech Harmony 890 remote. First, I'd have to buy wall jacks that are capable of being IR/RF controlled, have these installed and then set up the Harmony remote to control it if possible. Not a 100% certain that this will work.
Or the other option is to return the BO speakers before the 7 days run out...not too excited about that either.
I'd appreciate suggestions anyone can provide.
Cheers,
d
