1st March February 2012
Latest post 02-21-2009 8:23 PM by BMGHB. 8 replies.
02-20-2009 9:39 AM
BMGHB
- Joined on 05-12-2007
- Posts 219
BeoVision 7 - 40 / APPLE TV
Hello everybody,
Does anybody how to make an APPLE TV go into standby with a Beo4/5??
BMGHB
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
Re: BeoVision 7 - 40 / APPLE TV
You can go to the standby option through the menu. If you have the latest version, it should be somewhere under settings. Holding down the "Go" button will not work.
That entry for standby in the ATV menu structure came with the last update. I used it once, I believe it doesn't save much power.
Cheers
JK
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I am thinking of getting an Apple TV to use with our BV7. Our BV7 software does not have Apple TV in it. I plan to use an iTouch as the remote for it. Is there any reason to have the software updated to allow Beo 4 control if I will be using the iTouch?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
jk1002
- Boston USA
- Posts 1,620
I have an itouch but I rarely use the remote app. To be honest I am not sure if it can deal with selecting videos or buying content from the itunrs store. I just checked the website, it talks only about music, not full control.
If you want to avoid the software update, the Apple TV "can" learn third party remotes. It can't deal with the Beo4, but if you use an existing STB/PUC from your list and sttach the cable, you should find a product that support the navidation cross (includng holding up down fast reverse and go) as well as the exit key. I am sure that this can be made work.
Cheers
JK
Razlaw
- Illinois
- Posts 1,770
jk1002:
Cheers
JK
Thanks! The iTouch can be used to purchase music from the store. In fact, I find it easier on the iTouch than on the computer. But I do see what you mean, it might not be possible to purchase movies.
jk1002
- Boston USA
- Posts 1,620
i am not talking about itouch, but iremote. I think it controls only music, while apple remote can do more.
BMGHB
- Posts 219
Hi JK,
Which menu are you mentioning here? The BeoVision 7 menu, the Beovision 7 APPLE menu or the APPLE menu?
Which update? The APP SW for the BV7 or a new PUC/STB SW?
Thx in advance..
And have a nice weekend
BMGHB
jk1002
- Boston USA
- Posts 1,620
Apple TV menu. If you have the latest, under settings, last entry is standby.
BMGHB
- Posts 219
Thx JK
Page 1 of 1 (9 items)
