Latest post 02-21-2009 8:20 PM by BMGHB. 8 replies.
Page 1 of 1 (9 items)
  • 02-20-2009 9:38 AM
    BeoVision 5 / Control Swisscom box
    Hello fellow beoworlders,
    A friend have a BeoVision 5 - 42.
    He would like to control a Swisscom box with his Beo 4 remote control.
    Swisscom box data:
    Swisscom model kmm3010-SCB
    S/N..KF30SOH1DXXXX
    MAC ID 00-1E-6B-XX-XX-XX
    SAP 1253XX 0
    I can see that with STB-SW Central Europe 4.06 there is a box named SWISSCOM blue-win.
    Does anybody know if we can control the beforementioned box with this SW or some other solution.
    Best regards
    BMGHB
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
    Filed under:
  • 02-20-2009 5:41 PM In reply to
    • Luke
    • Top 200 Contributor
    • Joined on 02-03-2009
    • Switzerland
    • Posts 286
    Re: BeoVision 5 / Control Swisscom box
    I know what Bluewin is... but we don't have the TV yet so no idea !
    Sorry.
    Good to see that there are some others in Switzerland here...
    Anyone else here who would have an idea???
  • 02-20-2009 7:20 PM In reply to
    Allo Luke,
    Actually im from denmark but my friend lives in switzerland.
    What is bluewin?
    BMGHB
  • 02-21-2009 3:52 AM In reply to
    I Have the Bluewin Box from Swisscom, with the Beovision 7-32. You can take the STB SWISSCOM Blue-win, it works fine.
    Bluewin TV is digital-TV over IP.
    Beovision 7-32 MK I,Beolab 7-1, 2x Beolab 3, 2x Beolab 6000, Beolab 2, Beosound Ouverture, Beo5, Beocom 6000
  • 02-21-2009 12:52 PM In reply to
    Hi Postman,
    Thats sounds promising. Would you mind flipping the box over and check it is indeed the kmm3010-SCB box?
    Thx in advance :)
    BMGHB
  • 02-21-2009 1:29 PM In reply to
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Wow i just check'd there are three models they distribute at the moment. So far any of the ones we hook'd up with the PUC work'd fine. But i can't tell you if we really use'd all of them yet Wink.
    I will hook one of those up within the next two weeks. Afraid i can't give you an advice yet.
  • 02-21-2009 1:41 PM In reply to
    It is the KMM3010 Modell. All Swisscom Boxes using the same Remotecontrol.
  • 02-21-2009 1:53 PM In reply to
    • KibitoCH
    • Switzerland
    • Posts 82
    Good to know and what i've expected, thanks.
  • 02-21-2009 8:20 PM In reply to
    Thx PostmanBig Smile
