Latest post 02-27-2009 1:32 AM by Knubbi. 5 replies.
Page 1 of 1 (6 items)
  • 02-20-2009 4:14 AM
    How to put Mac in StandBy?
    I learned in this forum that this has been an issue for a long time and am just curious whether there is a solution in the meantime to put a Mac into Sleep mode with the Beo4?
    Thank s for any help!
    Ciao, Knubbi
    Cheers, Knubbi -- Beovision 7-40 MK3, 2x Beolab 5, 2x Beolab 8000
  • 02-20-2009 9:04 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: How to put Mac in StandBy?
    Push + hold GO should do it.
    If not, you can set your Mac to automatically shut down after a period of inactivity in Energy Saver in system prefs.
     Weekly top artists:
  • 02-20-2009 10:51 AM In reply to
    Does this really work for you? Here, with my BV 7-40 controlling a MacBook it doesn't work at all.
  • 02-20-2009 3:18 PM In reply to
    With the normal apple remote pushing the "play" button would work, however the Beo4 holding down the "go" button doesn't work. So standbay and fast forward backward is a no with the current STB/PUC I believe.
  • 02-21-2009 7:25 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    As said Go long and MENU (EXIT) long on Beo4 via PUC controller won`t work. As Alex said, use a timer in system settings - worked pretty well for me.
    Another way would be to use Remote Buddy, Sofa Control or.....
    Stefan
  • 02-27-2009 1:32 AM In reply to
    Problem is that if FrontRow was playing anything while shutting of the BV 7-40, the Mac will not enter standby as it is busy playing tracks.
    But you are probably aware of this as well Embarrassed
