Latest post 02-23-2009 7:13 PM by burantek. 11 replies.
Page 1 of 1 (12 items)
  • 02-19-2009 3:40 PM
    BV7 MKIII Picture Problem
    Our BV7 MKIII seems to have developed a strange problem. Periodically dark portions of the picture will be displayed as a bright red grid pattern  and some light portions will have small areas of a blue grid pattern. It does this with both satellite TV as well as DVDs played in the internal DVD player so it would seem to be a problem with the BV7. Also, it does not repeat. In other words watching a DVD it may do one time but then if the same scene is replayed it will not do it.
    I have talked to the dealer about but thought I would see if anybody else has ever experienced anything similiar.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 02-19-2009 3:43 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BV7 MKIII Picture Problem
    Haven't seen anything like that yet.  Did your dealer contact Tech Support?
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 02-19-2009 3:49 PM In reply to
    Dealer will be contacting them I took some photos this morning when it occurred and have emailed them to the dealer.
  • 02-22-2009 8:32 AM In reply to
    Must be a very unique problem...no other responses.
  • 02-23-2009 8:01 AM In reply to
    We think we have narrowed the problem down to occurring between 30 and 60 minutes after the TV is turned on.  We are watching closely to see if we can narrow it down to a specific point in time after turning it on.
  • 02-23-2009 1:44 PM In reply to
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Never seen that either, can you post these pictures?
  • 02-23-2009 3:56 PM In reply to
    deleted
  • 02-23-2009 4:20 PM In reply to
    the pic is worth a thousand words...
    believe it or not, i occasionally have seen something similar... on my avant!
    not very often and not nearly to the same extent as yours, and it seems predominantly to happen w/ local news shots w/ solid color areas framing "live action" and sometimes in the "live action" shot as well... just like your photo!
    i have not noticed it on any other sources though ...like DVD as you have -at least that i can remember... i always thought it was the broadcast???
    time does not seem to be an issue? -i will try to snap a pic of it.
    • B&o bottle opener
  • 02-23-2009 4:40 PM In reply to
    deleted
  • 02-23-2009 5:37 PM In reply to
    Could be a bad connection of the LVDS-cable. Very fragile cable. This cable connects the circuit board with the panel. I saw this problem with other brands before.
  • 02-23-2009 6:07 PM In reply to
    If that is what it is sounds like it would be a simple repair for the technician to perform.
  • 02-23-2009 7:13 PM In reply to
    i was wrong (don't tell the wife)...
    mine seems to be the inverse of yours... darkish-blueish patches on red areas.
    only happens as mentioned before -nothing as dramatic as yours!
    • B&o bottle opener
