I've been thinking about this product for years now, and B&O hasn't come out yet with a project like this.
To me it makes so much sense having a single product for both functions, BeoComs & BeoLink remote controls have so much in common:
- both have the same long & thin shape
- both are battery powered
- both have a screen
- both have a keypad & numbered keys
- imagine a Beo4 with a microphone inside the "O" from Olufsen , a loudspeaker between the screen and the first line with the sources, a backlit coloured display with 3 or 5 lines instead of one, a backlit keypad as well, only 2 batteries instead of 3 (to keep the weight at a reasonable level), a docking base for recharging, is it so hard to build nowadays for people like B&O??
Reunion Island is greeting you!
