Latest post 02-20-2009 4:18 PM by KibitoCH. 1 replies.
Page 1 of 1 (2 items)
  • 02-18-2009 3:01 PM
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Beo 5 and Eurovox STB
    Hi all - I have the opportunity to purchase a Eurovox set top box to replace my current V box which tends to freeze a lot. Can the Beo5 control it as it would any other STB i.e. get the channel logos programmed etc.... Any help appreciated as Beo 5 very close to being on order but not if it cannot work the Eurovox box.....
    Dave - Birmingham, UK
  • 02-20-2009 4:18 PM In reply to
    • KibitoCH
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Re: Beo 5 and Eurovox STB
    If Eurovox is the brand, then there isen't any STB decoder available.. directly. That doesen't mean it's impossible though. Often some STB Tables work for diffrent Brands/Types of STB's. You should contact your dealer and ask him to check it up with B&O Support.
