Latest post 02-18-2009 7:43 AM by Luke . 4 replies.
Page 1 of 1 (5 items)
  • 02-17-2009 5:29 PM
    Help! BeoSound 3 users only...
    Hi chaps... lost my mobile earlier today which I usually use as my alarm clock. Hence, need to find an alternative. The BeoSound 3 sounds like a good one! Can someone please remind me how to set the alarm on it for 7am tomorrow morning, SD card or Radio I don't mind. The manual is at my Mum's house which is 200 miles away!
    Thanks,
    Simon.
  • 02-17-2009 6:36 PM In reply to
    Re: Help! BeoSound 3 users only...
    The user manual is available on the main site.  This extract from it should help you...
    Chris.
    Make a Wake-up Timer
    The Wake-up Timer is a once-only Timer, and must be programmed each
    time you wish to use it.
    > While the system is in standby, press TIMER. The time for the latest
    Wake-up Timer is shown in the display. The digits blink.
    > Press  or  to fi nd the time you want the system to start playing.
    Press and hold  or  to step quickly to the desired time.
    > Press the button of the source you want to use for your Wake-up
    Timer; RADIO or A MEM. ‘Pr’ (for a radio program) or ‘A’ (for A MEM)
    is shown in the display. If you do not choose a source, the radio is used.
    > Press STORE to store the Wake-up Timer. The time for the Wake-up
    Timer is briefl y shown in the display.
  • 02-17-2009 7:06 PM In reply to
    Got nowhere with that! Nothing happened when I pressed the Timer button. Anyway, so tired so hitting the sack either way, alarm or no alarm. Thanks for your response anyway. I am sure the builders will wake me up when they arrive in the morning.
    Cheers,
    Simon.
  • 02-17-2009 7:53 PM In reply to
    simon,
    set an alarm w/ your newly purchased serene... it wakes me up every am!
    • B&o bottle opener
  • 02-18-2009 7:43 AM In reply to
    • Luke
    • Top 200 Contributor
    • Joined on 02-03-2009
    • Switzerland
    • Posts 286
    The Serene is much better.... it can go off every day of the business week without re setting it !
