Latest post 02-16-2009 3:30 PM by Craig. 3 replies.
Page 1 of 1 (4 items)
  • 02-15-2009 3:29 PM
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    BS9000 and PC in different rooms?
    I am planning to get a Beoport to enjoy N.MUSIC. My setup is that BS9000 is in the livingroom and the computer in a MCL link room. Is this kind of product placement supported by Beoport or do all the main components (audio master, pc and Beoport) need to be in the same room?
  • 02-16-2009 6:51 AM In reply to
    Re: BS9000 and PC in different rooms?
    Definately no reason to be in the same room, not sure though about the MCL. I have a setup with Beoport in the study and the BS9000 in the living room listening to N.MUSIC in the whole flat. This is all wired with ML.
    Cheers,
    Frank
  • 02-16-2009 1:38 PM In reply to
    • Mico
    • Finland
    • Posts 136
    Thanks,
    This clarifies my case. MCL might cause an issue because I need to find a way to attach the Beoport to the MCL cabling or link unit. The only way I could think is the MCL2-AV and one of the connections there. I do not know if they are two way and support Beoport though.
  • 02-16-2009 3:30 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Don't think you can connect via the MCL network you have. Your Beoport will have to be connected to the BS9000 with a Masterlink connection.
    CraigSmile
