1st March February 2012
02-15-2009 3:27 PM
nobby
- Joined on 04-21-2007
- Posts 539
Once you have worked it out ... I am open to offers in the region of £100.
p.s. the bits that should be mounted on the back have been removed.
Neil
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Re: Who knows what this is?
Hi Neil. Would I be right in thinking this is a dealers display item? Are we looking at the back, or the front?
Andy T.
nobby
- Posts 539
Not that I am aware of ... but perhaps you know more than I !
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
As you say it's a dealer item, I would say a remote mains switch. So only one piece of kit is powered up. Stops all the items turning on at the same time. Probably before dealers had the range reducers for the remotes.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
I think it could be something to do with speakers!!
as there are powerlink connectors
nobby
- Posts 539
They look like powerlink sockets ... but they are not ... some strange 4 wire interface.
Nickyg63
- Nottingham
- Posts 628
Is it B&O's first attempt at a games console??
The Beo-station 1
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
Is that the DeHaviland Transmogrifier? If it's a Mark IV or later it can actually use a pair of Pentas to summon a poltergeist!
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Jandyt
- Posts 13,004
Have you managed to operate it Neil. If not, try plugging it in, plugging a device in the left 3 pin socket, then Shift, Phono, 1 or Shift, phono, 2 If you have operated it, could you tell us what command you used please?
Craig
- Posts 4,855
nobby:
4 pin DIN, like an MX stand?
Craig
nobby
- Posts 539
4 pin din, like an MX stand ... but not for an MX stand.
As I have disassembled part of it ... I do not wish to plug it in until i have made it safe.
I get the feeling that Andy knows exactly what it is!
Neil
Craig
- Posts 4,855
Well I know the speaker switch thingy that Andy has uses Shift, Phono then 1 - 12 to select between up to 12 pairs of speakers. Can't think what else uses 4 pin DIN sockets. Are there any connections on the other side?
Craig
Xseries
- Joined on 04-16-2007
- Hampshire
- Posts 433
The link module shows this to be about 15 years old - it looks lke one 4 pin and one powerlink socket to control power via a Beolink - I am guessing for a TV, remote stand and video from an ex display......
Excellent find and worth £100 to some - 100 pence to others!
Brian
nobby
- Posts 539
Yes, my guess is that it is from this era ... it is in fact an early home cinema control unit ... curtains, projector, screen, lights control etc.
On the back there were 3 (yes three) LC2s mounted ... these have been removed ;)
So ... any takers?
Neil
gk31ax
- Joined on 04-18-2007
- Posts 220
Is it BEO time with a couple of sockets for a kettle/ Coffee maker???
Carl Sheerman
- Joined on 04-19-2007
- Plymouth UK
- Posts 173
Its a flux capacitor that gives out 21.1 gigawatt of power. An early B & O time device?
Xseries
- Hampshire
- Posts 433
Have you managed to make it control anything - using a BL1000 I would guess from that era? Are there any guidance notes?
Brian
