1st March February 2012
Latest post 02-16-2009 9:33 AM by bayerische. 17 replies.
02-15-2009 11:29 AM
Luke
- Joined on 02-03-2009
- Switzerland
- Posts 286
Variable line in to BeoLab 5
Is this possible at all ?
May have found a good deal on BL5's but the problem is we have a projector in the main living area so ideally at the moment would like to run it from our current system which is Onkyo TX-SR705 and all audio/video imputs are connected via HDMI. We planned to attach the BL5's to the receivers pre amp out, front left, front right but the manual of the BL5's says you should only use non regulated line in and adjust volume with Beo4 which wouldn't really work for us at the moment. The volume would be regulated with the receiver.
Any viable solutions (or is the only solution to get Beocentre 2 and Beovision 4 hehe) ??
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Re: Variable line in to BeoLab 5
You will need to control them via the Beo4 remote.
You need to turn them on and off, and adjust volume, you will also need a sync cable to go between the speakers, so that they syncronize the volume. If you buy used, a serial number older than 172XXXX will not work with the sync cable...
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Luke
- Switzerland
- Posts 286
Hmm maybe they are already too old then... they are December 2006. I will ask for the serial. Thanks for that !
koning
- Joined on 04-16-2007
- Netherlands
- Posts 2,670
2006
I think they are not to old!
Serial is underneath the big disk.
bayerische
- Helsinki, Finland
- Posts 3,593
Correction; The speaker need to be newer than: 17772145
-Andreas
koning
- Netherlands
- Posts 2,670
WHAT!!!!!!!
mine are 175XXXXX
So i can not use them with another (non-b&O) system
bayerische
- Helsinki, Finland
- Posts 3,593
Apparently not...
Beo should do their homework better...
I call this wrongful marketing.
-Andreas
soundproof
- Posts 2,340
I don't see a problem here, with what the threadstarter wishes to do, regardless of the generation of the BL5s?
Line in to the speakers will accept a variety of external sources - B&O's only requirement is that the signal level should not be in excess of 2V RMS, if it is higher, a passive attenuator should be used.
If you follow my suggestion in another thread of finding a good working volume for the speakers, and storing that, then you can control additional up/down volume with the receiver (in this case the Onkyo). Works beautifully with my setup, and should do so with any BL5 speaker.
The level I have set the speakers for, is my preferred listening level for digital music (fed via the coax s/pdif.)
When switching to a surround movie feed, I use the pre-outs on the receiver, and send the Front L/R signals to respective speakers, as the threadstarter asks. Due to how I have set up my surround system, my sound level for surround is six up "ticks" on the Beo4 (but that's just my setup, yours may differ). When I want to listen to a digital source again, I just hit LIST>RESET.
I use either my Beo4 or my universal remote to control the speakers.
Dave Moulton
- Joined on 05-12-2007
- Groton, MA, USA
- Posts 108
What Soundproof says is right. It's also approximately what I do. Once you have the default levels set on the Beo4, you use it to bring the speakers in and out of standby, and use the receiver volume (on its remote, probably) to control the level of the BL 5s. You don't need a sync cable for this.
Enjoy! The living will be oh, so good!!!
Best regards,
Dave Moulton
Dave
Sausalito Audio LLC
koning
- Netherlands
- Posts 2,670
B&O must stop with usermanuals,because what they describe DOESN'T work in the beginning of the product.
I think that's very odd
bayerische
- Helsinki, Finland
- Posts 3,593
koning:
That's right, and I would even go one further and say it is false marketing. We should wright a letter to B&O and ask for a free software update, since the update isn't going to be cheap, the speaker need to be disassembled.
From what I was led to believe we are talking hundreds of euros.
-Andreas
koning
- Netherlands
- Posts 2,670
Exactly false marketing!!!!
what sofware have your beolab's 5 bayerische? I have 1.62A
bayerische
- Helsinki, Finland
- Posts 3,593
koning:
Mine are 1,62... No "A" at the end.
-Andreas
koning
- Netherlands
- Posts 2,670
The "new" beolab 5 have a new volume chip and the software version is 3.00.
I ask keith Sanders a question and this is what I told me:
The latest release is Software 3.00a and provides the following improvement is only for production due to update of the volume control IC and new design of the according PCB meaning your units cannot be updated to version 3.00a unless the associated PCB is also replaced.
DoubleU
- Joined on 05-09-2007
- Posts 866
koning:
WHAT!!!!!!!
mine are 175XXXXX
This only applies for systems with a fixed line level output and if your BL5s are miles away from each other, since the ir of the beo4 is so strong nothing have to be synchronized.
In most cases there is pre-out on the receiver and the amp will take care of the volume adjustment. there is nothing to be synchronized. Just read Soundproof and Dave Moulton's replies.
bayerische
- Helsinki, Finland
- Posts 3,593
DoubleU:
koning:
WHAT!!!!!!!
mine are 175XXXXX
Yes, but Soundproofs and Dave solution, is after all a "workaround" solution.
-Andreas
soundproof
- Posts 2,340
Re. "workaround solution" --
Not really. It's what you're supposed to do if you connect to an external non-B&O source. No way to escape that.
No matter what kind of setup you have, you would have to set a working level for the speakers, relative to the output level of your source, if you're using the line-INs.
bayerische
- Helsinki, Finland
- Posts 3,593
soundproof:
Yes Soundproof, I just meant that not controlling the volume with a Beo remote is a bit risky, for instance when someone in a previous thread suggested having the Beolab 5's at maximum. I feel like that is risking it, one small stray signal and you'll be scared to death
The sync cable is in my opinion a great "add-on" if used with third party products, and it's always mentioned in the instruction manual to be used if the Beolab 5's are not connected to Beo equipment.
That was what I meant with a "workaround"...
-Andreas
Page 1 of 1 (18 items)
