Derek,
Good work!
Just for the record, could you put up a photo of your AC motor, showing what "pulley" you pried off, and where exactly you inserted a blob of oil!
Also regarding the AC hum, here are the 4 caps I replaced on mine, and the hum disappeared:
1. 1x Nichicon 4700uF 25V UHE1E472MHD6
2. 1 x Nichicon 220uF 16V BiPolar UVP1C221MPD
3. 2x United ChemiCon 4700uF 50V EKMH500VSN472MQ35T - actual capacitance is 4100uF so very close to the B&O original 4000uF spec. For this, I have also used Panasonic TSHA units (ECO-S1HA472BA) on other models with excellent results, but the KMH just fits better.
All are available at Digikey.
The picture shows them before I replaced the metal hold-down bar. The 2 smaller caps on the left were subsequently hot-glued to the chassis.
I also have a limited supply of Nichicon Muse Audiophile Power Capacitors 4700uF 35V and 63V, which are perfect for the main power supplies in the BeoMasters and BeoCenters. For pics and details, please PM me!
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
