Hi, all!
I just got a BeoCord 8002. It was advertised as "one channel not playing", and that is exactly the problem. Otherwise it seems to work. Belts are new. When playing a tape, only the Right channel is heard, and only the Right VU-meter will react. The two volume trimpots on the bottom are set one "notch" from the max setting.
Is there anything obvious I can check? I have a DTM, and can do some soldering, but have very limited knowledge of electronics...so any help must be very precise, please! I can post pictures where you can draw arrows etc. to guide me... I have the service manual, but it is of very little use to me.
I have cleaned the multi-pin contact leading from the tape heads to the PCB, and the relay next to it. Is there a way to measure the tape head, to see if it is faulty?
Any help is greatly appreciated!
/Folke
BG 6000 Quad (two!), BM 3000, BM 5000 (2005), BV S45, BV M70 with trumpet stands
