I'm currently replacing the foam on my RL140's woofers. The first two are finish and works well, no center problem.
Now I'm wondering, if the midtone ITT speaker has to be done. Why I'm asking, is that I can't get the speaker out of the cab. I have opened the seperate midtone cab and removed the four screws from the speaker, but it seems the the speaker is also glued to the front. I don't want to try remove it to find out the speaker is a rubber speaker and don't need repair.
Any able to tell, if the midtone is rubber or foam and need to be repaired. If foam, how to get it loose from the glue?
Best regards
Nis
