Latest post 02-14-2009 8:26 PM by Beolab. 5 replies.
Page 1 of 1 (6 items)
  • 02-14-2009 12:34 AM
    loudness setting on Beocenter 2
    Hello
    Recently i was changing sound settings on my beocenter 2, i.e treble, bass and loudness.
    Treble and bass change and I can audibly hear the difference, when selecting. 'Loudness' however appears to no longer work- it is able to be changed on the beocenter 2 display to on or off, but nothing changes with the actual sound. It used to work.... now it appears not to work.
    Beolab 9's are connected to the socket box.
    Initially i thought perhaps it had something to do with itunes/mp3's..but i have the same issue when playing CD's.
    It seems odd to me that treble bass work and 'loudness' doesnt...
    Any suggestions????
    David Coyne
    Sydney, Australia
    BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
  • 02-14-2009 2:05 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: loudness setting on Beocenter 2
    The Loudness control (as with all B&O systems) only has an affect at lower volumes. The idea is that you can still hear low frequencies etc... even when using the system for background music.
    Your BeoLab 9s have built in loudness circuits which too are only active at lower volumes, so I personally would avoid using any sort of loudness control on your BeoCenter 2, as you'll effectively be 'doubling' the loudness control.
     Weekly top artists:
  • 02-14-2009 5:16 AM In reply to
    I know one thing for sure,
    With the beolab's 5 you don't need loudness even at very low volumeSmile
  • 02-14-2009 5:48 PM In reply to
    Thank you both... It does seem odd though that I used to be able to notice the difference with it on or off.... now nothing....
    Is it possible something is wrong with my beocentre 2?
    David Coyne
  • 02-14-2009 6:13 PM In reply to
    • Alex
    • Posts 2,990
    I seriously doubt it. If there was something wrong with the loudness circuits, then it would almost certainly show itself in a much more disturbing way.
     Weekly top artists:
  • 02-14-2009 8:26 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Loudness is only avaieble from volume 0-35 on Bc2...
    BL8000 MkII Black
