Hi Martin:
The belt is quite loose and actually chould be changed because it slips a bit so it is not pulling the platter over.
The front most leaf spring won't adjust enough to compensate. I can get it to lift but it also lifts the part in the front transport lock to the point where it touches the roof of the collar.
The question the begs, well can't you lower the two leaf springs behind?
I have tried and have made things worse. The threaded peg with nut and washer assembly claping down on the leaf spring is most difficult to align. Do you know how to set this up properly? Ie how high rods should be and how far down the lower nut should be?
I fished this thing out of a garbage can and so many things are out not where they should be!
Thanks,
Derek
