Latest post 02-13-2009 4:17 PM by jgn. 4 replies.
Page 1 of 1 (5 items)
  • 02-13-2009 9:25 AM
    • jgn
    • Not Ranked
    • Joined on 04-17-2007
    • Dublin
    • Posts 6
    Sky and Sk+ IR
    This may have been answered before (but I cannot find it) so apologies in advance.
    I have just upgraded to Sky+ from NTL and I don't know where the IR receiver on the Sky+ box is located for the STB-C. Same question for the new style standard Pace Sky box (as I got multiroom) ?
    Big difference in picture quaity and sound btw.
    John
  • 02-13-2009 9:32 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Sky and Sk+ IR
    Hi John.
    As there are different models of the Sky+ box, I suggest you find the correct placement with the assistance of another person.
    Whilst you move the IR about, get them to repeatedly press numbers on the Beo4 until they are read accurately. That's the way I positioned mine.
    Andy T.
    Poor me, never win owt!
  • 02-13-2009 10:07 AM In reply to
    Re: Sky and Sk+ IR
    Agree - my Pace Sky+ box has the sensor between the last of the horizontal row of silver buttons and the LED showing the remote is operating - you can often make out a translucent area on the front which is not marked - this would be a good area to try first. Remember Sky+ uses a different set of codes to plain Sky so you will need to change the STB-C type.
  • 02-13-2009 12:39 PM In reply to
    Re: Sky and Sk+ IR
    You can often find the receiver when you shine a small bright flashlight very close to the front panel; it's usually something resembling a bare LED. The same trick is good for checking speaker drivers without removing the frets Wink
    -mika
  • 02-13-2009 4:17 PM In reply to
    • jgn
    • Not Ranked
    • Dublin
    • Posts 6
    Re: Sky and Sk+ IR
    Thanks guys, got them.
    For the sake of others searching for this:
    the 2009 Variant of Sky+ has the IR receiver immediately to the right of the row of buttons on the front.
    the PACE Sky Box DS445 i.e the curvy one, has the IR receiver where the envelope or mail symbol is.
