Latest post 02-13-2009 4:30 PM by hebo. 4 replies.
Page 1 of 1 (5 items)
  • 02-13-2009 9:12 AM
    APPLE TV TO AVANT
    My local retailer said its not poss but my mate says it is.
    Huh?
    Confused at the moment. Is it possible and if it is, what do I need?
    Cheers
  • 02-13-2009 10:59 AM In reply to
    Re: APPLE TV TO AVANT
    Who to thrust Laughing
  • 02-13-2009 11:24 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    It used to be possible by converting the component output of the AppleTV to a RGB signal (these types of converters can be bought for less then 100 euro).
    But I am not a 100% sure because I recently read some comments on the internet saying that the appleTV adds a signal to disturb this conversion. Solutions seem to be downgrading the AppleTV firmware.....
    But as said: All this information is not from own experience but from reading on the internet (what led me to the conclusion to wait until I have a tv with component or HDMI input before I bu a apple TV).
    Good Luck,
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 02-13-2009 11:31 AM In reply to
    You can buy a component-RGB converter, you loose some of the picture quality, but it is possible :)
    To use your Beo4/5 to control the apple tv box, you need a SW update ( change of an IC) and an Ir cable.
  • 02-13-2009 4:30 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    I use this hack and it works just fine,
    http://www.youtube.com/watch?v=84lRorvaAvk
    If the power is lost you have to make it again,
    otherwise it works great!!!
    and it´s much cheaper
     BV10
