I'm sure they're not worried in Struer. After all it doesn't have a built in Beosystem 3 :-).
From Engadget.com
Right on cue, Sharp has offered two of its new Blu-ray-equipped AQUOS HDTVs up for pre-order. The 32-inch LC-32BD60U and 37-inch LC-37BD60U both feature 1080p panels, a trio of HDMI inputs, six millisecond response times and a slot-loading Blu-ray player on the side. Best of all, the 32-incher is coming up a dollar under a grand, while the 37-inch sibling will only run you $1,199. Sure, they're a bit pricey compared to optical drive-less alternatives, but if you've been holding off on simultaneously scratching the BD + new TV itch, here's your sign.
[Via GadgetReview]
