1st March February 2012
Latest post 02-28-2009 10:43 AM by tournedos. 11 replies.
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
Re: More white stuff landing...
Congratulations, a nice set. A white beomaster 6000 would fit them nicely.
br
Chr.
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
I agree However, those are far and between over here and not very practical to get from abroad... I was very surprised how good these speakers sound - I've only heard before my other pair of S80.2's which have incorrect woofers.
The same lot included a pair of RL6000's, a BM5000, CD50 and MCP. The price will be good if I manage to fix the BM, otherwise I'll just try to be happy with these very nice speakers
BTW, was the original colour clean white (as the BS6500 behind) or yellowish? I suppose these have faded, but the tone is incredibly even and fits my walls nicely...
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
tournedos:
I'm not entirely sure of the original "whiteness" of these but I have some white MC120.2's which are also more of a creamy white than the pure white of the system 6500. The ones I have came from the original owner and a smoke free home so I can only assume they are the original colour. It is hard to tell from photo's but mine seem a little less yellow than yours Mika.
Have you cleaned them thoroughly? I've found baby wipes to be the best product for this, non aggressive and great for removing grime & nicotine.
BTW, as I'm a collector of Art Deco originals, can you tell me any more about the panther/cheetah figure on your BG6500?
Cheers
Chris.
tournedos
- Finland
- Posts 5,808
Thanks, Chris - the pic maybe shows them more yellow than they are because of some spotlights. I haven't had time to do much with these yet, I'll certainly take a try with the baby wipes (the Pentas could use some cleaning as well...). Also, the previous owner apparently has made a new pair of mounting holes for the stands to get the speakers a bit lower.
The panther, I brought it back from Tanzania in 2006, along with a 2 ft giraffe and another smaller one They're supposed to be made of ebony, but I'm not quite sure as they have lightened a little over the years... definitely wood and very heavy for the size, though. This kind of woodwork is typical over there for skinning the tourists, and usually a bit tacky; but whoever made this panther succeeded quite well imho. And I was with locals, so I probably paid a tenth of the usual price
Friedmett
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
Congratz!
I had the option to get a pair of S120 while the S80.2 were being rebuild by Dillen. Being white editon it could be cool to try 2 pairs with the white editon 6000 system. I got all 3 units minus the speakers first at an auction.
Condition of both pairs were really good. Minor scratches but not noticeable. Despite the usual foamrot and the lack of stands for S80.2 at first they look really good and sound great as speaker pair 1 and 2.
I would say cream like for the colour. My LX5500 is white in part and it's more clear white than the 6000 system. The 6000 system matches the Beovox's perfectly. I don't think smoke has much to do with it as the early catalouges show the same cream like colur if you look close enough. In the end it depends on the lightning and placement.
j0hnbarker
- LS28/GB
- Posts 2,002
Nice Mika!
I'm always taken with how easily old and newer B&O stuff sits together in the same room. They look great!
As for the whiteness issue, I have just been bought a Beocom 1000 as a present, and though it was originally white, it has faded equally in all parts back to what I can only describe as a 'lemon' colour. It still looks great though :)
soundchoice70
- Joined on 08-07-2008
- Posts 201
Hi Mika,
Nice collection!
The white will have definitely changed, as the finish is a lacquer (basically a spray paint finish), the paint will 'yellow' with age especially if it was an oil based paint, this is normal... For instance i have some series 7 chairs at home in white (well at least when I bought them) they are over 10 years now and are definitely a shade of cream no matter how much they are cleaned... Would suggest using a non abrasive cream cleaner and they will come back a bit whiter / brighter tho.
Laurence.
tournedos
- Finland
- Posts 5,808
Yes... the price could have been better in normal auction ending about now, but I decided to "buy it now" since I'm now in Lisbon
The RL's were fine but took a lot of effort getting presentable (you'll find a thread in the workshop forum).
camshaft
- Pennsylvania, USA
- Posts 575
Mika, the older white items do tend to have a slightly creamier color than the pure white of the white stacking systems. As mentioned, the white was usually painted on back then (although I believe some may have been laminated). If you want to try it, a mild polishing compound will often remove the slightly yellow oxidized layer of paint and freshen the surface.
Austin
Edit: Mika, I looked at my white 4002 again. The white is close enough to the later plastic whites that you can't really tell a difference. If your paint looks noticeably creamier it may have yellowed slightly, at which point I think the polish would help.
-Austin (resident audiophile skeptic)
tournedos
- Finland
- Posts 5,808
Thanks. I'll maybe try on the bottom side what happens with cleaning; I actually like the colour as it is now!
Page 1 of 1 (12 items)
