Latest post 02-13-2009 5:27 AM by Roger. 5 replies.
Page 1 of 1 (6 items)
  • 02-12-2009 11:46 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Beosystem 3 removal from Beovision 9
    Anyone done this?
    Is it complicated?  Any instructions out there somewhere?
    MJM
    I'm ready for something new that I actually want to buy!
  • 02-12-2009 12:10 PM In reply to
    Re: Beosystem 3 removal from Beovision 9
    One has to question why you would even consider this? Clearly you have a reason. No idea I ama afraid but I am sure a BV9 owner or a dealr might shed some light.
    Simon.
  • 02-12-2009 12:16 PM In reply to
    mjmedlo:
    Anyone done this?
    MJM
    the manuals are on site... and you are a goldie.
    i have not looked at them, but i assume they would contain disassembly instructions...
    • B&o bottle opener
  • 02-12-2009 3:28 PM In reply to
    It's screwed in just like a BeoSystem 3 wall bracket (if you've ever seen one). Just unplug the cables and take it off. Nothing special. I did it once to steal BS3 in a pinch and didn't need to look at directions.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 02-12-2009 4:31 PM In reply to
    I guess if you need instructions to remove it then you best leave well alone! :I
  • 02-13-2009 5:27 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    As Trips said, it is quite obvious when you look at it - it sits as a backpack on the BV9. If in doubt ask your dealer, some of them were not aware of the fact that initially you had to deactivate the PIN code before uploading new S/W to the BS3 box - and it freezed. Only solution was to hook off the BS3 box and return it to B&O (or a skilled tech support center).
    Roger
