Latest post 02-13-2009 3:57 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 02-12-2009 6:42 AM
    Avant 32 and ipod.
    Can some please tell me how I can get the ipod to work the the Avant 32 (VCR). I have connected the audio into the top sockets (behind the clock) but I can't seem to configure the input from the setup menu.
    Many Thanks
    Steve
    Filed under:
  • 02-12-2009 6:52 AM In reply to
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Re: Avant 32 and ipod.
    Hi Steve
    You've connected it in the right place. Now all you need to do is select 'Camcorder' on you Beo4 remote control and it should work fine.
    If you don't have 'Camcorder' in the list on your remote, you can simply add it by pressing the power button (red dot) and 'list' button together. The Beo4 will then display 'Add?' on its display. You then need to hit 'Go' then search throgh all the options until you find 'Camcorder'
    Good Luck!
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 02-12-2009 2:21 PM In reply to
    Brill, now sorted.
    Pity that it doesn't kill the picture to the tube though when not  seeing a video signal.
    Cheers
    Steve
  • 02-13-2009 3:57 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Surely, it can't be the Avant so it must be the iPod that caused the choice of the vintage forum for this post.   Indifferent
