Latest post 02-11-2009 6:13 AM by crissbiscit. 4 replies.
Page 1 of 1 (5 items)
  • 02-11-2009 5:08 AM
    Replacing a din plug lead on a Beocord 3500 cassette deck.
    I've just bought a Beocord 3500 cassette deck which is in great nik except the din plug lead has been severed, I wondered how hard it would be to replace the lead if anyone can help. Also does anyone know if it's possible to convert it to normal RCA leads for use with a non B&O amp? Any help or advice is greatly appreciated.
    What's your favourite tune?
  • 02-11-2009 5:36 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Replacing a din plug lead on a Beocord 3500 cassette deck.
    If adept with a soldering iron should be no problem - I don't know if the lead is a figure of 8 configuration or of circular aspect with the cores inside - try steve at sounds heavenly he may be of assistance - he's a forum member!
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 02-11-2009 5:51 AM In reply to
    Thanks Tony, where is Sounds Heavenly? I'm in the UK. Do they have a website?
  • 02-11-2009 6:02 AM In reply to
    Hi crissbiscit,
    Yes, we do have a website and we are based in Leicestershire, UK.  I am concsious that the forum rules prevent me from advertising, but if the moderators do not object to me answering your direct question, I will add a link to the Sounds Heavenly website below.
    By the way, thanks for the recommendation Tony!
    [Note to moderators: If you feel that this breaches the "no advertising" policy, please let me know and I will delete this post]
    Sounds Heavenly website: www.soundsheavenly.co.uk
    Changing the DIN plug to RCA outputs is not a problem and this can be either done by replacing the plug on the fitted cable, or by adding a convertor cable.  I can either provide assistance or send you a diagram if you wish to do this yourself.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 02-11-2009 6:13 AM In reply to
    Hi Steve,
    I'm not the most technically accomplished person in the world but I'd have a go if it was simple enough, the old cable is installed in the deck but the plug has been cut off at the end, whichever is the simplest method would suit me (and my ability) best..
