Latest post 02-10-2009 2:26 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 02-10-2009 6:22 AM
    • Bliss
    • Not Ranked
    • Joined on 08-05-2007
    • Posts 31
    Beogram 8000 / 8002 wood trim change
    I know that it is possible for some Beograms to remove the wood trim panels quite easily, but is this also possible with a Beogram 8000 / 8002? I 'd like to switch panels between an 8000 and and 8002. If possible, how to do it?
  • 02-10-2009 1:34 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 8000 / 8002 wood trim change
    It's glued on these decks. The glue will losen if you'll let a hairdrier assist you but it's not always easy.
    It may be easier to swap the entire plastic frame...
  • 02-10-2009 2:05 PM In reply to
    If you swap the entire composite frame, please be aware that the molded catridge compartment is different between BG 8002 and BG 8000.
    BG 8000 is molded for MMC 20 series
    BG 8002 is molded for MMC 1 series
    Derek
  • 02-10-2009 2:26 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, that's right.  Laughing
