Gerd is correct, although I would always recommend that if you still have the original mark 1 cables (VERY thin, c.2mm diameter) then when you replace your speakers, this is a good time to go for some new mark 3 cables anyway.  The mark 1 cables are not the most robust option and if you are burying your cables in walls or ceilings, mark 2 or 3 cables give you some "future-proofing" if you make changes further down the line.
Best regards,
Steve.
									    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
