Latest post 02-11-2009 5:16 PM by Ian. 5 replies.
Page 1 of 1 (6 items)
  • 02-07-2009 6:42 PM
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    BL2000 - Won't Work
    I have a BL2000 that I'm trying to connect to my main system (BV6-BS9000-BV1). I have a masterlink cable/junction boxes between each one but when I connect the BL2000 I press play and nothing happens, pressing CD sometimes brings the turns the left LED green for a few seconds then back to red. The timer is off BTW.
    The only thing I can think off is that either the ML cable is wired incorrectly, or the BL2000 itself is faulty.
    Anybody have any ideas?
    Ian
  • 02-07-2009 6:53 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: BL2000 - Won't Work
    Have you put the BL2000 in link option 6?
    Poor me, never win owt!
  • 02-08-2009 3:25 AM In reply to
    can you test the lab2000 in another location?
    Jandyt:
    I didn't realize you could change the options on these?
  • 02-11-2009 12:05 PM In reply to
    • francis
    • Münster, Germany
    • Posts 108
    Have you fixed your problem already?
    If not it sometimes helps to unplug all mains and ML cables, wait for a minute or so, and then plug in all ML cables first, then the mains, starting with your Audio/Video Master.
    |BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
  • 02-11-2009 2:20 PM In reply to
    • Ian
    • UK
    • Posts 132
    It is in option 6, but I have B&O coming round tonight to help me set it up. I'll keep you posted.
    Thanks for the replies.
    Ian
  • 02-11-2009 5:16 PM In reply to
    • Ian
    • UK
    • Posts 132
    I've got it working (it was a masterlink problem), but I can't seem to get it working via beolik wireless. Does anybody know if a BL2000 can work via Wireless (I heard the old (mk1) BL3500 needed powerlink and masterlink (from the wireless receiver to work), but the mk2 version worked on masterlink only). The BL2000 doesn't have PL, so maybe it can't work wirelessely?
    Ian
