Latest post 05-26-2007 7:08 AM by frog. 5 replies.
Page 1 of 1 (6 items)
  • 05-25-2007 3:46 PM
    No Sound from BeoMedia
    Dear BeoPhiles,
    My BeoMedia flashed up an error message which I didn't understand, so following telephone call to dealer  I rebooted it. Error message disappeared but so did sound. BeoMedia is connected to an old BV 5 via a CVBS/AUDIO to SCART cable. N.MUSIC and N.RADIO appear to be playing on screen but no sound, just a clicking. I notice when I reboot the BeoMedia I have 5 seconds to select "BeoMedia Recovery," but as I have not had the confidence to connect a keyboard and mouse, it defaults to "BeoMedia." The dealer is convinced it is simply a loose SCART but I don't agree.
    Finally, the only documentation I received when I purchased this infuriating black box six months ago was a "Setting-up Guide." I this week received a PDF of a "Getting Started" manual which is so much more useful. Did B & O deliberately not include any useful instructions and should the "Getting Started" manual be added to the site?
    Looking forward to your collective expertise.
  • 05-25-2007 4:44 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: No Sound from BeoMedia
    Plug some headphones into the Beomedia audio socket - that should confirm whether the SCART isn't connected correctly
  • 05-25-2007 5:32 PM In reply to
    The manuals are on site. I agree with you that a really good reference manual is missing - but I have never seen one! Laughing
  • 05-25-2007 5:50 PM In reply to
    Dear Frog,
    Thank you for your prompt reply. I did plug headphones into AUDIO with no joy. I also plugged a pair of PHONOS in to the BeoMedia (between CVBS and AUDIO) and the BV5 via a COMPOSITE/SCART adapter. Again no sound.
    Thanks again.
  • 05-26-2007 4:36 AM In reply to
    On my Beoport + BS3200 sometimes N.Radio or N.Music doesn't react.
    I see it (and hear it ofcourse) that it doesn't work.
    The BV7 display shows N.Radio only after approx. 8 seconds.
    When all is o.k. "N.Radio" is visible on this display within 2 seconds.
    So if I may guess?
    There is something wrong with your software inside the Beomedia.
  • 05-26-2007 7:08 AM In reply to
    • frog
    • Posts 191
    Looks like you need a rebuild. Afraid you'll have to connect a keyboard to the Beomedia and choose Recovery.
