thx for the replies!
i had a chance to open it up last night, and briefly do a look over.
everything looks fine, but i ran some of the factory tests across the (2) resistors and clearly the right channel is lame. if i offset the balance to the right, it sounds ok, but clearly not correct.
i also notice quite a bit of heat build up on the front plate in proximity to the radicator and the tuning knob area. after a while of running (2 hours) the radicator quit functioning. after power on/off it did come back...
i think that there is more going on than meets the eye... i have sourced some 3000uF 25v's but they are radically smaller in size than what is present on the board... i am missing something? the balance pot seems to be fine... could just replacing the 3000uF's be sufficient?
all (3) bulbs are shot -is there one also in the radicator dial? i don't think so...
i will likely have to take this completely apart, something i am not looking fwd to doing, though it is not *that* complex...
any thoughts before the grand dissection?
