Latest post 02-04-2009 2:25 PM by stotty1111. 5 replies.
Page 1 of 1 (6 items)
  • 02-04-2009 1:26 PM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Beo4 NiMh batteries
    Can I use rechargeable NiMh (Energizer 2650mAh) Batteries in a Beo4.
  • 02-04-2009 1:31 PM In reply to
    Re: Beo4 NiMh batteries
    I can't see why not, but I also fail to see why. Beo4 uses extremely little power (probably a fraction of the amount NiMH batteries discharge by themselves when disconnected) and the cell voltage would be a little low to begin with. You would probably be recharging them every other month.
    I recommend Energizer Lithiums. In applications like this they can last five times longer than alkaline batteries (it is not just ad speak!) and will not go old so fast. I have yet to replace a single one since I started putting them in all my remotes.
    -mika
  • 02-04-2009 1:33 PM In reply to
    yes, but...
    You better use normaal batteries,rechargeable batteries have less power.
    also they are faster empty.
  • 02-04-2009 1:35 PM In reply to
    • UK
    • Posts 970
    tournedos:
    My batteries are running out and the rechargeables are the only ones I have spare.
  • 02-04-2009 1:38 PM In reply to
    OK, then just put them in Smile
    -mika
  • 02-04-2009 2:25 PM In reply to
    • stotty1111
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    I use NiMh batteries in all applications remote / radio control systems - they hold charge better than Ni Cads and do not suffer recharge memory problems! I would recommend 'em
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
