Latest post 07-30-2009 1:53 PM by moxxey. 5 replies.
Page 1 of 1 (6 items)
  • 02-03-2009 9:26 AM
    BV7-40 MkIII - Power light flashing
    Hi all, maybe someone can help on a strange flashing power light that has started to appear on my BV7-40 MkIII since I installed Apple TV with HDMI
    Once the BV is in standby after a while the red light power light starts flashing.
    I originally thought it was because the Apple TV had also gone into standby but when I switch on the Apple TV was displaying the screen saver so couldn't have gone into standby.
    Now I'm a bit confused on what is causing it. Has anyone else experienced the issue?
  • 02-03-2009 9:39 AM In reply to
    Re: BV7-40 MkIII - Power light flashing
    welcome to beoworld!
    take a look here, see if it is what you are talking about...
    • B&o bottle opener
  • 07-30-2009 7:40 AM In reply to
    hi. i have the same issue happening on my bv7 mk4. for no apparent reason. i'm waiting for my dealer to get back to me on this one. this has happened on the replacement tv b&O gave me since on the original one decided to display blacks and reds in green. not a good state of affairs when you consider the cost is the best part of £10k. i regret buying  this tv. on reflection a samsung would have been much better buy. im actually quite angry at what has happened.
  • 07-30-2009 7:50 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    robbykhu:
    Yes, this happened to me - lots of red lines across my BV7-40 MKIV screen. Dealer gave me a MKIII as a replacement and ordered another. New MKIV arrived and I've not any problems since (although I do have a linkroom audio delay issue).
  • 07-30-2009 8:11 AM In reply to
    moxxey:
    Hi Moxxey
    I have adressed this issue with B&O and got the answer that this can be callibrated. They told me to adress the issue to my dealer.
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 07-30-2009 1:53 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Cool, thanks. I'll look in to it. No idea why it couldn't be 'calibrated' from inception though. The MKIII didn't have the audio delays.
