1st March February 2012
Latest post 02-06-2009 6:14 PM by samuk. 19 replies.
02-03-2009 6:35 AM
samuk
- Joined on 01-31-2009
- Posts 15
Thanks and need help for my B&O
Hello every one
First of all Iam samuk and thank you for letting me this wonderful forum
I have recived Beovision LX5500, VCR Vx4500,Beomaster 6500 abd Beogram CD6500 with Beo link1000 from my one of the director after his upgrade.
I never used any other than Beovision until i had a accidental damege to it screen last year. It means last 06 years all the units are in the box of my room.
Last week some how I was able to get in to the site and find out I can connect my Beomaster to non B&O speakers.Thanks fot the advice just to let you know my Beomaster is fine with my BOSE speakers.
But iam having a problem with incresing and decresing the volume and listn to the radio.
I bealieve my Beolink is not respondingIt was very fine untilllast day of my Beovision.
can you help me on this please.Any restting of how to check my beolink working or manually we can raise the volume up
Thank you again,
Samuk
Stonk
- Joined on 04-16-2007
- Marlow, Bucks, UK
- Posts 1,688
Re: Thanks and need help for my B&O
Hello Samuk
Welcome to Beoworld.
I think you should
first check that the Beolink1000 is working correctly. Using a digital
camera or cameraphone point the remote towards the camera lense and
press volume to see in the camera display if the infa red lights up on
the Beolink1000.
Steve
If you think nobody cares, try missing a couple of payments.
Xseries
- Hampshire
- Posts 433
Samuk,
The remote is key to the operation of your system pieces. I keep a spare (or 4) so I can adjust volume and so on.
Steve,
A most useful tip about the camera! I have not come across that one before (is it just me or is it new to others?). I have just been tyring out several remotes - including non B&O to test it!
If only I had known about it a few years ago when wondering if my remote or TV was not working.....
Brian
Graham1982
- Joined on 11-22-2007
- Cambridge, England
- Posts 531
Hi:
This is a fairly new trick to me. I think I picked it up on here and I have used it on several occasions. It has proved to be invaluable.
Graham
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Used the camera phone trick for few years now. With a BL1000, I can see it with my eye. As long it is in a dark room.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Were you using the Beomaster connected to the TV for sound using the TV speakers? If so I think the beomaster may be in the wrong option.
You may need to reset it to option 1.
Chris.
j0hnbarker
- LS28/GB
- Posts 2,002
Try the IR remote/camera phone trick with a two-way B&O product. It's ace - like watching War of the Worlds or Star Trek or something!
samuk
- Posts 15
Dear All
Thanks a millions for the all reply. I tried with camara and phone last night I cannot see any red light and same time I have clean the connectors as well. Iam 100/100 It used to work fine until our TV has broken.
To let you know now I have connect my Beomaster to myBeo gram CD 6500 with pair of Bose speakers. Earlier I have only used my BL1000 with my Beo vision LX5500(no other systems are attached)
If myBL1000 need to be reset pls let me know how and or worst come can it repair any suggestion,
Have a good day
Best Regds,
Graham1982
- Posts 531
Hi:
You will not see a red light but a brightish flash (white light I think) if your remote is working. Here is what you need to do:
1 Place your camera or phone camera lens in close proximity to theremote control's emitter bulb (you should be able to see this through the view-finder).
2. Whilst looking through the viewfinder, depress any of the remote's buttons. A bright flash should be seen on the camera's view screen.
Sorry if this is all fairly obvious. However, have you checked the battery terminals of the remote for corosion and/or have you tried fresh batteries? Sometimes it is the simplest things that cause the biggest problems.
Graham
samuk
- Posts 15
Dear Greham,
sir Thanks for the reply. I will try again today evening. I have replced all new battries why because when I aws not using my BL1000(over 02 Years) I have remove the battries,
Best Regds,
Samuk
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Graham1982:
This can be a real problem since all Beolink 1000s are getting rather old. In the old days, you could still buy cheap non-alkaline batteries (you'd think most B&O first owners could have afforded decent batteries, but...) and they very often leaked when left in for too long. I've seen Beolink 1000s so corroded in the inside that it was a small wonder they still worked!
Even after you clean the battery contacts, the wires that connect to the battery compartment may have corroded solderings that do not work anymore. Even more so, if the battery holder is loose and moves inside the remote. Easy to fix if you know how to solder, but requires disassembly of the remote. Be sure to try fresh batteries first - sometimes touching corroded electronics just makes things worse and you're off to a complete overhaul, meaning ultrasonic cleaning etc...
samuk
- Posts 15
Dear Mr Greham,
I will try with another set of battries today and see how is goes and try clean the terminal properly,
Thank you,
Best Regds,
Samuk
samuk
- Posts 15
Good Morning!
Dear Mr Greham and all,
I have change the battaries and check I can see the white blue lights are flashing on my BL1000.
But Sadly in wont do anything.I have pressed the rest button too No luck. Can you tell me what to do or how to rest .
Only thing i worried my speaker cable connection + and - is that going to be a cause theBL1000 not working,
Thank you,
Rest Regds,
Samuk
tournedos
- Finland
- Posts 5,808
samuk:
No, that can't be the problem. Perhaps the original owner had the tv and the Beomaster connected together, and the Beomaster might be programmed to option 0 (i.e it doesn't use its own IR receiver, just takes commands from the tv).
Try this to program the Beomaster to option 1, that is enable its own remote receiver:
With the Beomaster in standby, press SOUND - 1 - STORE on the Beolink 1000. Hopefully you will see the standby LED flash briefly, and from then on the remote should work.
samuk
- Posts 15
Thanks for the reply. I will surely do that Today and let all you know. Iam sure pervious owner had connected all the units to his Beovision and used B4
Thanks again,
Best Regds,
Samuk
samuk
- Posts 15
Good Morning!
Hello all Iam samuk again sorry for the all trouble. I have tried to change trhe setting of my BL1000 but sorry to tell you it didnt worked out,
I have pressed sound then 1 and store nothing happen and i cannot see flickering on the Beomaster(which has got a red stand by(hope) is solid)
I also check the BL1000 flashing light but want to tell you when i pressed the numders and CD, Radio lights are comes on but pressing sound and the off wonts see any light,
Thank You,
Best Regds,
Samuk
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Hi Samuk. To me, it looks like the contact buttons inside your Beolink 1000 are faulty. Is there any way to borrow a remote from someone? Beolink 1000s come up for sale frequently on eBay and are not usually very expensive.
Andy T.
Stonk
- Marlow, Bucks, UK
- Posts 1,688
Hi Samuk,
From what you have said I understand that:
You can operate certain functions with the remote but not the volume and off
buttons?
You have tested the remote using a camera and can see it light up when
pressing CD & radio but nothing happens when you press the volume up, down
or off buttons?
I am certain the cause of your problem is a common fault within the BL1000
itself. Easily repairable. You will need to take the BL1000 apart and check the
contact sheet which is a plastic sheet that sits between the rubber buttons and
the circuit board. The contact sheet has dimples with dark spots. You will
probably find that the ones you use most have flaked away through wear and age.
I have repaired these in the past using normal kitchen foil cut with a paper
hole puncher and then gluing the little foil discs onto the contact sheet. The
glue has to be flexible - I used post-it note type glue which comes on a
dispenser.
Or you couuld buy another remote.
Steve
samuk
- Posts 15
Hi ,
Thanks for reply and advice. I will try to find out another rmote and see weather it will work. I can see the blue light are flashing even when iam pressing arrows next to the sound button but when i press only sound or rest or off button i cannot see the light.
Thanks,
Samuk
samuk
- Posts 15
Dear all
Thank you so much for the all the help and guidence. I am happily inform you that my Beomaster is working fine now. I do not want to watch Tv just want to sit and listen my easy listining and jazz,
I borough friend of remote and the system stART WORKING AND THE SAME TIME I WAS PUSHING MY BL 1000 keys suddnley my BL1000 start working.
Iam really happy specially today is Friday,
Thank you all. I will ask more from you very near future,
Best regds,
samuk
Page 1 of 1 (20 items)
