Latest post 04-19-2009 5:13 AM by blong. 10 replies.
Page 1 of 1 (11 items)
  • 01-31-2009 3:35 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    LX2502 Sound but no picture
    Just collected a faulty LX2502 today, the problem is there is no picture only sound. Really I only brought it as it came with a working BL1000. Well the TV is in mint condition so I thought I would take a look. When I removed the back and switched it on the end of the tube is glowing as it should. When you turn it off you get the white flash in the middle of the screen. So I assume I have power to the screen. Does anyone have any idea where to look next?
    CraigSmile
  • 02-01-2009 2:34 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: LX2502 Sound but no picture
    1. Service Manual
    2. Try a hair dryer to warm some of the components on the first couple of boards.  It is usually capacitors that cause the problems.
    3.  Be careful
    4. Keep the external good parts and buy another TV for next to nothing and make 1 good from 2 bad!
  • 02-01-2009 3:54 AM In reply to
    Could be a bad cap in the tuner section or AV switch...
    Hmmm, check it with the AV port, connect a VCR or DVD player.
  • 02-01-2009 7:32 AM In reply to
    • Craig
    • Posts 4,855
    Die_Bogener:
    Both the RF connection and AV port are the same.
    CraigSmile
  • 02-02-2009 1:26 PM In reply to
    Did you already check http://www.repairfaq.org/sam/tvfaq.htm ?
    Great website with lots of info on fixing TV's, symptom oriented. Has been a great help for me! (and I learned a lot from it!)
    Laughing
  • 02-03-2009 1:46 PM In reply to
    • Craig
    • Posts 4,855
    Premiumverum:
    Laughing
    Thanks for the link, I wil have good look through it later. Welcome to Beoworld BTW.Wink
    CraigSmile
  • 04-16-2009 11:45 AM In reply to
    • blong
    • Not Ranked
    • Joined on 02-20-2009
    • Posts 47
    • Silver Member
    The white flash you get at switch off - does it look like a line across the screen centre the split second you see it?  If so, it's probably field collapse ie no vertical scan  (I'm assuming this set is a CRT type - will have a look when I get a minute) = Brian (Northumberland)
  • 04-16-2009 2:22 PM In reply to
    • onyx
    • Not Ranked
    • Joined on 04-15-2009
    • Posts 8
    hi,
    try to rotate (just a little) the G2 regulation pot and watch to the screen if something appear...
  • 04-16-2009 2:58 PM In reply to
    • blong
    • Not Ranked
    • Posts 47
    • Silver Member
    Yes, as Onyx has indicated - turn the lower of the two pots (not the Focus one) clockwise little by little - if it is loss of vertical drive, you will see a bright line across centre of screen, but first mark the position of the pot so you can put it back!  I am assuming that you can recognise the LIne Output Transformer, as this is what we refer to.  Let us know what happens -  good luck = Brian (Northumberland)
  • 04-16-2009 3:33 PM In reply to
    • blong
    • Not Ranked
    • Posts 47
    • Silver Member
    More to think about = If it does turn out to be loss of field scan, the next test is to check for 24 volts between pins 4 and 10 of IC2 (the vertical output chip).  If the 24 volts is missing, you would need to check the supply circuit which comes off the LOPT at pins 12 and 4 - two diodes (D39 and D40), two safety resistors (R74 and R75) and the two electrolytics (C44 and C45).  I'm assuming you have a multi-meter and know how to use it!  It can get very interesting - and frustrating!!  Let us know how you get on =  Brian (Northumberland)
  • 04-19-2009 5:13 AM In reply to
    • blong
    • Not Ranked
    • Posts 47
    • Silver Member
    Hi = My Guru, BJ 'Baz' Hunter, has passed on the following info:  B+O introduced a mod for the Lx2502 concerning field collapse.
    It is:  If the Vertical Output chip has to be replaced (TDA2170 no longer available), replace with TDA8172 and Adaptor PCB and change 4R78 to 3.3k and 4R85 to 0R56 = Brian (N)
