1st March February 2012
01-30-2009 7:18 PM
phult
- Joined on 01-31-2009
- Posts 24
Blue Ray seems to finally have hit prime time. What in everyones opinion is the best blue ray player (in terms of picture/sound quality as well as seemless interoperability with the BV7 Mark III/BS 3).
From what I understand it needs to be able to output the new HD audio formats via PCM as well as have a good PUC.
I am looking at Pioneer, Sony, and Panasonic but can't for the life of me figure out which one would be best
PierreR
- Joined on 08-05-2007
- Posts 41
No adaptions is needed to work with BV7 mkIII, just plug the HDMI in :-)
The PS3 is fast between the menues on BD and have proberly a better picture quiality on dvd than the dvdplayer in BV7, but i won`t say that it is the best BD player on the marked.
Oppo is comming whit a BD player in few monthe (in Europe) you shut take a look at that, many have high expatations to that player and i thing that in price/ quaility it`s gonna be the best.
beoaus
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 445
Maybe the Panasonic DMR-BW500. It has a lot more features than just playing blue ray. I'd say better picture quality and sound though it is expensive. The PUC config is being written and will be available shortly.
Beoaus.
kawo
- Joined on 04-17-2007
- Posts 516
Looking for the "best" blu ray player might not be an easy task. I ask myself the same question a month ago. The challenge at least from my point of view is that the picture quality outputting a blu ray from the most current models is very close together.
I could not see any difference between Panasonic, Samsung and Denon.
So next step for me was to understand if there is any noticable difference with playing back standard DVD's. Samsungs player with the build in Reon chip was in theory much better than the Panasonic, but I have to say, with the BS3 in between, it was hard to see the difference even on my 2,24m screen.
Finally, picture performance was much closer together than the reviews I have seen in most of the magazins so my purchasing decission was based on how easy the system could be operate, noise level and price. And not to forget how the PUC is performing.
Long story short, I ordered a Panasonic BD35. It is not perfect (e.g. slow operation) but a lot bang for the buck
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Beobird
- Joined on 04-19-2007
- Netherlands
- Posts 506
You can buy the Goldmund blu-ray player if you want the best, but it's not cheap (12000,-) .
I should look at a Panasonic BD55 in the range 300,-. Very good player with the latest technologies.
We Can't Get Enough B&O Stuff...
Carl Sheerman
- Plymouth UK
- Posts 173
Well guys had my BV7 Mk 3 40 inch with software 5.04 installed yesterday including the ability to control the PS3 from the Beo 5 and the picture quality is simply staggering. This is accomplished using the Nyco USB stick that simply goes into a USB port. Watched Apocalypto and the colors are simply amazing.
The PS3 plays games, upscales DVDs, acts as a media server. What other BR player on the market can boast that amount of flexibility. I also have control of my Apple Tv and Virgin box.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
beodude:
The PS3 is also increadibly easy to update the firmware on it over the internet, whereas other players are not set up to do this. So you will always be taking full advantage of your Blu Ray movies because of this.
BDP-S350 (and I would expect the more expensive models also) does this as well.
beodude
- Posts 120
The PS3 has a slot loading drive. It is loaded by sliding the disc through a slot at the front of the player, so like a normal dvd player:
This can also be done when the PS3 is standing up vertically
phult
- Posts 24
I don't have a PlayStation but from reading reviews it seems that while it is an excellent blue ray player (in terms of responsiveness perhaps the best) it is not that great when it comes to DVD playback.
Also my understanding was that you cannot use the Beo4 remote to turn the playstation on and off (though perhaps this is not that big a problem) even if you have the USB stick.
Regarding the new Panasonic and Denon players does anyone know if the PUC lists have been updated for them yet.
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
Pioneer BD 80 and Denon´s new BD transport are the best.
Then Sony S350 and S550 are placed at second.
And the new Oppo BD with the Anchor Bay chip i think will be a hard one to beat!
Carl Sheerman
- Plymouth UK
- Posts 173
The Sony PS3 can be turned off with the addition of the latest PS3 software due to a turn system off facility on the menu bar. The PS3 can only be turned on with the controller.
So with the Nyco stick you can turn it off but not on initially.
TerryM
- Posts 208
Beolab:
How can one place the Sony S350/550 ahead of their flagship BDP-S5000ES?
It is a superb player,which is rated in some quarters as the equal of the much more expensive Denon 3800.
Beolab
- Sweden
- Posts 535
TerryM:
Beolab:
The PQ are the same in the S550 and S5000ES! It´s just the soundprocessing, dual lasers and built quality who it´s better in the ES series...
But the picture on BD are the same! Tacke a look if you come by a Sony Concept Center...
Regards
TerryM
- Posts 208
Beolab:
TerryM:
Beolab:
Regards
this may be true with all of the S5000ES's additional PQ options switched off.
However,with it's SBM,and the Reality Enhancer,option engaged the BD PQ is taken to a far higher level than that of the S350/550 series.
I do own a S5000ES,but there are enough user reports on the relevent avsforum,and avforum,threads to indicate how it compares to other high end players.
Regards.
phult
- Posts 24
One question that has not been answered in any of these posts is do the PUC codes work equally well.
The Dennon is clearly a fantastic machine but has anyone actually used one with the B&O PUC codes? The same for the Panasonic and Sony machines.
Finally, is anyone having issues with decoding the new HD formats?
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Just replaced our Sony BDP-S300 with the BDP-S550. So far I am very impressed and very happy with the 550.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Flappo The Grate
- Posts 703
i've had 3 ps3's in the last 18 months and have to say not terribly impressed with their reliability , my last one had to go back to sony with the game disc still in it , lost all my game saves , the lot
also the pic is very grainy , i've read that there are better players pq wise
pros : wifi sw update , games
cons : unreliable , grainy pq
i'd buy one for gaming and occasional movie watching , but for a superb tv like a bv7 i'd probably go for the top of the range denon , now that looks a real beauty !
why spend £8k on a tv then skimp on the source ??
