Latest post 02-08-2009 1:21 PM by tomsloat. 4 replies.
Page 1 of 1 (5 items)
  • 01-30-2009 7:03 PM
    beomaster 2200 disaster
    hi hope you can help. i had a perfectly functioning bm2200 when i got it it diddn't come with an ariel so i borrowed the one from my portable tv which worked perfectley as a short term measure. when i got a replacment i plugged it in to the 240-300 ohm connector. now the tuner sounds awful and wont hold a station .i measured the resistance of the new ariel and despite having the correct plug measured about 85ohms .does anyone have any idea what might have been damaged i have ordered a capacitor kit from martin will this help ?
    many thanks
     tom
  • 01-31-2009 2:57 AM In reply to
    Re: beomaster 2200 disaster
    I doubt the aerial did anything - I would guess that it just needs servicing. I take it going back to the TV aerial doesn't help!! I think the service pack from Martin is a good start but suggest that the power rail voltage probably needs looking at whilst in there.
  • 01-31-2009 4:45 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Probably a coincedence.
    Capacitors at the power supply board will probably be to blame. Replace the caps, you can't really trust anything
    before that has been taken care of.
    Measuring DC ohmic value on an antenna won't tell you its impedance.
  • 01-31-2009 7:42 AM In reply to
    thanks for the help i'll get the caps in and go from there
    thanks again
    tom
  • 02-08-2009 1:21 PM In reply to
    just an update fitted new power supply caps and hey presto all is now good
    thanks again to all
    tom
